trying to find a 12v wire with a fuse?
Old Aug 13, 2008 | 08:17 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
im just trying to find a useful 12v wire in my car taht is already connected to the fuse box.
i already have a few items being powered from the 12v wire from my radio
i dont want to put too much off that wire
i have a complete digital dash that i need to power somehow
any suggestions?
if i must wire directly to the battery what size fuse would i neeed to protect my dash?
just alittle help guys
normal size wire that you see all over the car incase your worried about the guage of the wire
Old Aug 15, 2008 | 10:47 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: trying to find a 12v wire with a fuse?
Camaro or T/A?
Never mind.
The 10A gages circuit has pink/black wires going all over the place. The 10A ECM circuit also has a pink/black wire. Then there's the 20A turn b/u circuit that is dark blue.
There are no other circuits that are powered continously from run through bulb test to start positions of the key.
I can't imagine the dash is drawing much power so I guess even a 3A or a 5A fuse would be plenty. This would protect even the thinnest wiring.
Max fuse size for wiring has been stated quite recently here.
Old Aug 15, 2008 | 11:20 AM
Bobby_80s's Avatar
Axle/Gears: no idea
so just for ha ha's
if i wired directly to the battery a 3-5amp fuse should be good enough for my digital dash?
if i didnt want to go digging for those wires you mentioed
Old Aug 15, 2008 | 07:47 PM
Bobby_80s's Avatar
Axle/Gears: no idea
well?
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
apie2546
Aug 8, 2015 07:12 AM
