electirc fan wiring, please help.
Old Aug 13, 2008 | 09:48 PM
tweakhat's Avatar
Car: 1986 Trans AM
Engine: LS1/T56
Axle/Gears: 3.83
can anyo ne help me with my electric fan, its wired so it comes on when the key is turne on, bu when you crank the car up and turn it off it burns up the fuse, the guy that did it has a orange wire running into a single connector and a a black one going to ground, the orange one plugs into the end of the co nnector then loops and plugs into the same connector but 2 (i guess you could say prongs?) over. i want to know how i can wire it to come on with the key..and not blow fuses. im thinking of a toggle switch setup if no one can help me, thanks alot.
Old Aug 13, 2008 | 10:00 PM
RobSS1113's Avatar
Re: electirc fan wiring, please help.
is it the dual fans or single.
The previous owner of my hacked up 91Z vert went ape chit on wiring up things all over the place.. some were down well with solder and other were half azzed.
Mine come on when you turn on the key and stay on when the car is ON and I noticed that he or they spliced a wire on the realys mounted on the top side of the drivers side firewall and attached a wire to it / taped it up and grouded it to the frame that holds the relays. I disconnected them at the moment ONLY because Im trying to figure other things out and Im trying to eliminate things 1 at a time.
if you want I'll pm you a pic of my relays how they are.... NO toggle switch needed in the car NOR do you need to tap into the fuse box.
Old Aug 14, 2008 | 01:53 AM
tweakhat's Avatar
Car: 1986 Trans AM
Engine: LS1/T56
Axle/Gears: 3.83
sure man i would love that, so it will come on all the time like i wanted and not blow fuses this way? thats my main issue.
oh yeah its a single fan.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Bull86
Aug 10, 2015 05:43 PM
