inline fuse to battery or find 12v ignition wire?
Old Aug 16, 2008 | 08:46 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
im currently using the stock 12v wire and ground wire in my gauge wire harness for my aftermarket digital dash
i have issues with some of my digital displays when using windows, brake, turn signal, headlights. not going into great detail since it didnt get me anywehre in my last thread
so lets stick to basics
to rule out the power source and the ground wire i'm going to first try a different ground source, then if still problems i want to try directly wiring to get 12v from the battery
if go directly to the battery for the 12v what size amp fuse should i use? 10-20-30????? and put a switch on it since i dont want the gauges on when the car is off
or try a 12v ignition wire? and if i use an ignition 12v wire what fuse is that on in the fuse box?
or what else do i have for options?
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
apie2546
Aug 8, 2015 07:12 AM
