All kinds of problems
Old Aug 17, 2008 | 10:25 AM
Samdweezel05's Avatar
There have been a few things going on with this car since I brought it home. I had a problem with the key being loose in the switch and the VATS not reading the chip so I got a couple of resistors and fixed that. Sometimes when you turn the key all it will do is make the starter relay click real fast by my left foot. Sometimes you will try to start it and it will loose all power to everything. It will act like you unhooked the battery. All on it's own it will come back to life and you can start it right up. It is a new battery with new terminals. I have removed, cleaned and reinstalled all the wires on the starter. The way the relay was clicking, it sounds like another bad ground. Is there a main spot under the dash where the ground wires come together? This is the last thing I need to fix and it will be ready for paint.
Phil
Old Aug 19, 2008 | 06:06 PM
Re: All kinds of problems
Not that any one here gives a crap but the problem has been fixed thank's to the help of all the guys over at the corvette forum. I guess if it had been a performance related question I would have had all the help I wanted. Best of luck to all of you with stupid questions that will never be answered.
Phil
jhawkeye
May 25, 2022 06:33 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
db057
Aug 22, 2015 08:17 PM
novaderrik
Aug 10, 2015 12:44 PM
Newguy91rs
Aug 7, 2015 09:51 PM
