VATS not supplying a good ground to start enable relay
Old Aug 24, 2008 | 07:22 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
This is a 4th Gen LT1 conversion in my '87 Firebird. Car is running but I've had to wire the starter enable relay yellow/black wire directly to ground. The VATS module wouldn't give it a good enough ground to crank engine. It would just give a partial rotation of the starter like it was a dead battery. I still have the security of the VATS shutting the injectors down after a couple seconds (when I unplug the key connector), but I'd like it to control the engine cranking again. Any body else run into this?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
