Modified 89 Camaro start problem
Old Aug 26, 2008 | 06:59 PM
pimpflea's Avatar
Car: 1990 IROC-Z Coupe
Engine: 383
Hi people. I have an intermittent problem starting my Camaro. I have a 383 stroker with an MSD 6AL and Blaster Coil. Sometimes when I go to start it, the engine will just turn over for ages and not fire up. Firstly I changed all the plugs, and it started and I thought I had the problem solved. Then it happened again, so I thought maybe I flattened the battery a bit turning it over too much. So I charged the battery and it started. Then it happened again, so I charged the battery again but it still would not start.
I put the mutli-meter across the battery and it reads 12.66 Volts, is this a reliable indication that the battery is ok or not? I put the multi-meter across the coil input wires and get no reading while cranking, and I have checked and there is no spark.
Finally I was able to start the car with the charger hooked up to the battery to give it a little extra kick.
Does this mean my battery is about to or has already collapsed? I think the battery is about 4+ years old.
Cheers for any input
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
92camaroJoe
Aug 13, 2015 06:07 AM
