Turn signal headlight idea.
Old Aug 28, 2008 | 08:03 PM
ĦMR.AWESOME!'s Avatar
Car: '92 RS
Engine: 305 TBI
I noticed while driving a Taurus the other night that when I turned on the left turn signal, a light came on to illuminate the left side. I could see where I was turning into to and it was pretty cool. It does it for the right side as well, btw.
I want to make my car do that but am a little confused on how I would go about it. Looking at the wiring diagram didn't help much. When the turn signal is switched on, how does it produce a blinking pattern? I need to be able to get a constant flow of current to at least get a relay to stay on. I don't know how I can get that. I don't want to have to run wires all the way from the dash, either. And while we're at it, what makes the clicking sound anyway?
Andrew
Old Aug 28, 2008 | 08:12 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Turn signal headlight idea.
The part that makes the turn signals flash is called "turn flasher" and it makes the clicking noise. It's under the dash, next to the fuse box. A round cylindrical part with two prongs.
This diagram shows it at the top of the page, right under the fuse: http://www.austinthirdgen.org/mkport...ithout_T61.jpg
Hope this helps.
Lou
Old Aug 28, 2008 | 08:28 PM
Car: '92 RS
Engine: 305 TBI
That does help. Thanks. Does the current that comes out of the "Turn Flasher" pulsate? Is that what causes the lights to go on and off? I don't want to have to climb under the dash to find out if I dont have to.
Old Aug 29, 2008 | 08:53 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Simplistically speaking, there is a constant 12v feed to the flasher. There's a mechanical mechanism inside the little can that clicks on and off (audible) and provides the on-off flash to the lights.
Old Aug 29, 2008 | 03:31 PM
Car: '92 RS
Engine: 305 TBI
Alright. Sounds good. I'm gonna screw around with this and see if I can get it to work. I'll post what happens.
Old Sep 10, 2008 | 12:32 AM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Ah, yes... The old-school turning lamps...
You'll need a set of lamps to illuminate and then design yourself a "missing-pulse" detection circuit to light the appropriate lamp and turn it off when the turn signal stops. Our cars do not have the appropriate signals from the turn signal switch assembly to simply do the task. All +12 feeds from the turn signal switch will flash.
This is a different circuit I designed many years ago, but it should get you started. This one actually makes your turn signal lamps into DRL lamps when not flashing...
Old Sep 10, 2008 | 01:54 PM
Car: '92 RS
Engine: 305 TBI
Thanks for the circuit. That might come in handy. What I was actually thinking of doing, was to splice in a wire before the the turn flasher box (because its a constant current there) and then run that to a relay which would turn on the lights. I don't see any problems with that method do you?
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
