End Result: no start, see for more
Old Aug 28, 2008 | 10:16 PM
mercdeking's Avatar
Car: 1985 Camaro Iroc-Z/Z28
Axle/Gears: 9 bolt borg werner, gears unknown
I'm still fairly new at diagnosing stuff; need pointers at where to look and for 'dummies' type answers. I hate electrical!
It started today, yesterday my car ran fine but today at around 915-920am when I was about to go to work...
I put my ignition key into the ignition and I turned it, it primed the pump and as I was about to turn it a bit more to activate the starter a weird noise and nothing, no clicks and no noises, even my accessories stopped working.
My lights still turn on though but I don't have any power to my hatch nor do I hear the starter nor do I see the check engine light turn on. I quit messing with it and got into another vehicle and drove to work.
When I got back I tried again, I plugged in the key and turned the key and it primed the pump and I clicked it again to start the car and no noise no nothing. Again all my accessories it seems like my hatch stopped working.
Tried again a bit later and still nothing, so it appears that it will get to the point of cranking then everything cuts out real quick and disables my car for a bit, either way my car doesn't start.
+++Currently, no power at all; not even my headlights, will take in my battery tomorrow. Figured by the time I got it out and drove to autozone they would be close to closing and I would not get my battery tested properly anyways.
Any suggestions on where to look for tomorrow?
I'm going to take my battery to test right now or tomorrow if I can't get it off in the next 15 or so minutes and the drive to autozone.
Last edited by mercdeking; Aug 29, 2008 at 01:04 AM. Reason: Further clarification
Old Aug 29, 2008 | 06:45 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: End Result: no start, see for more
Just check your cable connections at the battery first for tightness and corrosion.
Next check the fusible links at the starter.
Old Aug 29, 2008 | 07:16 PM
mercdeking's Avatar
Where were you yesterday! Lol!
I had my battery tested today at Autozone and I mentioned my problem after my battery tested good. He told me my battery was good enough to keep my lights and stuff going but if I had a bad connection it would do what my car was doing. His best guess and yours were dead on; I got some battery spray cleaner and a battery brush and new cable clamps/tposts whatever you call those things and everything fires up like a champ again.
Thanks for the reply, problem solved. Only cost me $15.00
Good thing too because I was thinking it was part of the ignition so I was going to start removing my interior panels to search for a short in the harness somewhere which I didn't look forward too!
Last edited by mercdeking; Aug 29, 2008 at 07:18 PM. Reason: Further clarification
hectre13
Dec 11, 2023 08:14 AM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mizz0313
Aug 12, 2015 06:45 AM
