I keep on blowing fuses HELP!!
Old Sep 2, 2008 | 09:51 PM
bigboy123's Avatar
Well as you all know, you need to pull the light lever towards you to turn the interior and exterior lights on in the camaro. Well i am restoring my camaro, and i pulled out all the interior and exterior lights to paint it. But yesterday i turned on the lights so that i could illuminate my gauges, to pull my car in, and the lights quickly went on then went off.
Turns out it was a bad fuse, so i put a new fuse in and the same thing happened, so there is most likely a short somewhere. Do any of you know where it could be or what my problem is. I was thinking maybe one of the times i washed the car, water got into the headlight connector, Please helpp!!!
Old Sep 2, 2008 | 09:58 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: I keep on blowing fuses HELP!!
if it all worked fine before you messed with your lights, check and recheck those areas.
i just recently installed a new pioneer cd player. i ended up not using a few wires and left them danging behind with nothing covering the exposed copper.
...two days later i kept blowing fuses until i pulled the cd player back out and saw my mistake. taped up my unused wires, good as new.
oh, don't write off an easy fix. i ended up replacing my headlight switch because i thought i was too good to make a silly mistake.
Old Sep 2, 2008 | 10:17 PM
bigboy123's Avatar
Ya i just put in a new kenwood cd player and now that i think about it, i did start blowing fuses right around that time, so i am going to take my dc player out and look for unused wires, but you said you taped the wires? what did you tape them to?
Old Dec 4, 2008 | 09:47 PM
a1990camaro's Avatar
Car: 1990 RS tbi camaro
Engine: 5.0 tbi stock, hooker headers
dont tape the wires to anything he meant wrap them up in electrical tape to prevent the exposed wire from touchig anything
Old Dec 5, 2008 | 01:02 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
hence the reason you can buy a camaro/firebird wiring harness for your stereo off hifisoundconnection.com for about 5 bux. solder the one you get with the deck and the OEM plug in one and violla! no wire fires or hack-n-slash stereo jobs
Just tape up the ends of the wire to make sure they dont make contact with anything, this is waay more common than i had hoped, i just had a bit more faith in people but half the time i go into a fuse blowing car the owner left exposed wires, sometimes i feel bad for charging them but good will doesnt pay the bills i guess
hope it works out, id trace over your lights too, may take an hour but atleast youll know whats going on lol
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
