headlight relay
Old Sep 5, 2008 | 07:58 PM
vick54's Avatar
headlight relay
does anyone know where the headlight relay is located on a 92 camaro rs?? i went to an electrician to get the problem fixed but it was to expensive all he told me that the problem was a relay that will take like 4hrs to change and the part it self would be like $100. any help will be greatly appreciated.
Old Sep 5, 2008 | 09:05 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: headlight relay
I don't know what headlight relay your talking about on a camaro but,I would advise you not to go back to that place.
I've never seen any relay on a third gen that costs $100 alone.
Old Sep 5, 2008 | 09:30 PM
CamaroRider's Avatar
Re: headlight relay
Ask him to point to the relay.
My 1989 Camaro RS 305 FI Vin E (TBI) has a headlight switch. No relays are involved for headlights in my stock setup.
Old Sep 5, 2008 | 10:19 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: headlight relay
No relays in either of mine. The switch does contain a breaker which opens for excess current, then resets itself when it cools down.
Old Sep 6, 2008 | 12:04 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: headlight relay
Definitely stay away from that scammer. Next thing you know, he'll be selling you blinker fluid and muffler bearings.
What are your symptoms? The wiring for our headlights isn't that complicated. Power goes through the headlight switch, through the hi/lo beam switch and then directly to the headlights.
Lou
Old Sep 6, 2008 | 08:20 AM
Re: headlight relay
Then through the headlights to a => GOOD GROUND <=.
Old Sep 6, 2008 | 12:26 PM
vick54's Avatar
Re: headlight relay
well the headlights were working perfectly fine when they suddenly went off. i checked the fuse box and everything seems to be fine. i have noticed that when i try to click the hi beams nothing happens not even the light on the dashboard turns on. could it be the switch and how much would that cost??
well im definitly not going back to that place thank you guys.
thunder57
Nov 7, 2015 02:28 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
