External Ignition Coil Issues...
Old Sep 12, 2008 | 10:39 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I recently bought an MSD Blaster - 2 coil (MSD-8202) canister style for my car, but it just won't fit. The car originally had a big cap HEI distributor with coil-in-cap, but I had to switch to a small cap distributor in order to clear the supercharger.
I was hoping to mount the coil on the pass. side of the distributor, but it's too big and interferes with the vacuum advance. I can't mount it on the intake because since I have a blower, it's just not your standard intake.
Looks like I'll need one of the smaller external coils, and I'm now looking at the E-core type of coils. I have these 3 in mind:
SUM-850500
PerTronix 60104
ACCEL 140008
All available at Summit Auto. Which would you get? Any other recommendations?
Old Sep 14, 2008 | 12:54 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: External Ignition Coil Issues...
I know this isnt the aftermarket vendor review board,but FYI I`ve been through 3 of the smaller external msd blaster coils in the past 3 or 4 years.I dont know about the other ones you mentioned but the msd units seem to just die.Well one of them was arcing through a crack on the plug tower.I have seen people mount them under hood but if you`v`e got a s/c i`m sure realestate is at a premium.My stock one has never failed.If i go back to an aftermarket one I will keep my stock one in the trunk.
db057
Jan 10, 2020 08:55 PM
MM2Robinson
Oct 1, 2017 09:16 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
Jlanz55
Sep 6, 2015 02:35 PM
