Quick VATS question... Did bypass, still doesn't work!
Old Sep 24, 2008 | 08:59 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
To keep it short....
This is VATS issue #2 for me on this car.
On the '92, a while back I wired a set of resistors (matched identically to the key, 1.87kohms) to the 2 wire connector. It has worked fine for 6 years, but for the last couple, it started working intermittently.
A few weeks ago it stopped working altogether, so I figured that I'd replace the string of resistors.
Before installing, the resistance matched the key...
After installing, the resistance when measured across the resistors is 1.6xkohm.
I removed the resistors to make sure one of them did get toasted by the soldering iron, and the resistance was again 1.87kohm.
I reinstalled the resistors and the car still will not start, the security light is still on...
I checked the fuse for VATS and it's good.
I've got a Chiltons manual, but the wiring diagram colors don't really match what I'm seeing under the dash, so I'm at a loss when looking for things... not sure where the VATS module is, etc... i The only thing I've been able to pin down are those two wires!
Am I missing something here?
Why would the resistance drop when connected?
Can you suggest anything for me to check out?
Thanks!
Old Sep 25, 2008 | 03:25 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Re: Quick VATS question... Did bypass, still doesn't work!
Suggestions?
Old Sep 26, 2008 | 01:24 PM
wastedemu's Avatar
Is the car cranking over?
If it is are the injectors firing?
If they are not firing get a VATS bypass module, it gets hardwired to the blue wire from your VATS module which is located behind the ECM under the passenger side of the dash(at least thats where i found mine)
the module only cost me 30 bucks and worked right away, I have a 91 firebird with a 30Hz system
Old Sep 26, 2008 | 01:59 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Thanks for the response....
The car isn't cranking over at all... Will the VATS bypass module still bypass the whole system altogether?
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
happyhapka
Aug 15, 2015 04:42 PM
