no ideas
Old Sep 26, 2008 | 01:20 AM
Enyce31082's Avatar
Car: 1987 Pontiac Trans Am
no ideas
ok so i put in a keyless entry alarm remote start. tested it 5 times and everything was fine. next morning i remote start the car and it s fine and i go to work. im leaving work i remote start the car and the car is sitting at 2000 rpm. i put my key in and try to kick it down and it wont. i try to drive it home and it wont let me go past 20 mph. and check engine light is on. my mechanic red the codes and a bunch came on for all different things. they reset it and they came back plus 2 more. any ideas woud be great. i also changed the cruise control switch tues as well and i remember seeing a pink and black wire not connect so i re connected them as well i dunno if that would help
Old Sep 26, 2008 | 03:13 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: no ideas
did you splice all the wires or did you have to cut any? What remote system do you have?
Old Sep 26, 2008 | 09:21 PM
Enyce31082's Avatar
Re: no ideas
the alarm is made by auto command. i see my friend spliced a wire inot the wire loom goin to 2 fuel injectors. y if he was looking for a tach wire??
Old Sep 27, 2008 | 12:42 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: no ideas
yeah, that should probably be disconnected...the tach wire is on the blaster coil, no where near the injectors...
Old Oct 1, 2008 | 04:12 AM
Enyce31082's Avatar
Re: no ideas
ok so i d/c everything and now i cant get the idle past 1500 rpm. i changed the tps and stil nothing and yes i calibrated it all and nothing changes. now what cause im outta ideas
Old Oct 1, 2008 | 08:47 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: no ideas
It could also be this pink/black wire. Maybe it was disconnected on purpose.
Another thing to consider is fuses. I'd look at injector fuses specifically. If your friend was connecting tach and injectors, one bank of injectors might have blown the fuse, making the car idle but not giving it any power to actually drive.
Lou
Old Oct 2, 2008 | 09:38 PM
Enyce31082's Avatar
Re: no ideas
and which fuses are the ones for the injectors. i checked all the ones i saw under the driver s side and none were blown. and i just found out that the interior lights by the feet stay on when doors are closed and dome light goes off. wtf else am i gonna find
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
