my dist. cap shocked the $#!t out of me!!
Old Oct 2, 2008 | 07:20 PM
85ZzZ4's Avatar
Car: 2005 Chevy Colorado/ 1985 Z28
Engine: fast burn zz4
Transmission: th350
Axle/Gears: 10 bolt (has to go) 3:23 gears
what could cause my dist cap to shock me? i just switched to an accel high performance coil and was adjusting the timing and the screw that holds the coil down shocked the crap out of me... whats the deal? bad ground maybe?
Old Oct 2, 2008 | 07:50 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: my dist. cap shocked the $#!t out of me!!
make sure your cap is on tight. also check all the wires. you should be able to put hands all over the cap and not get shocked. if its nighttime, pop the hood, start the engine and look for sparks.
Old Oct 2, 2008 | 07:51 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
had that happen to me once. it was because one of my plug wires wasnt one the plug all the way so i guess i was less resistance then the plug. so it shocked me pretty good.
Old Oct 3, 2008 | 09:00 AM
85ZzZ4's Avatar
Transmission: th350
thanks for the input, i'll check into that stuff as soon as i get back from vacation...
pjsparts
Oct 29, 2025 06:39 PM
Justins86bird
Sep 27, 2015 09:43 AM
84redta
Sep 19, 2015 09:58 AM
Saxondale
Sep 15, 2015 06:42 PM
87camaro87
Sep 9, 2015 10:29 PM
