Test light flashes on and off ??
Old Sep 26, 2008 | 05:29 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
On my 89 Firebird I have a bad battery drain. I have connected a test light in between the positive battery cable and positive terminal and of course it lit up. I removed the wire from the alternator, no change. I then removed each fuse and each wire plugged into the fuse box one by one and the only one that made a change was the CTSY fuse. With the fuse in the test light remains on, if I remove the fuse the test light flashes on and off.
I have never seen this before. What should I do next??
Old Sep 26, 2008 | 07:52 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Re: Test light flashes on and off ??
Okay I forgot after I found the CTSY fuse problem to go back through and recheck the fuses before that one. I found that the flashing test light will stop when I pull the tail fuse.
Is there a relay for the tail lights?
Old Sep 28, 2008 | 01:41 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
I found the problem. Its a good thing I can figure stuff out on my own I guess!!
GTAman
Mar 15, 2019 11:40 AM
soarestransam
Sep 1, 2015 04:00 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
