4th gen wiring swap
Old Sep 29, 2008 | 04:20 PM
tpidude1's Avatar
Car: 82 trans am,Project
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
4th gen wiring swap
Ok heres what I have to do.I have a 82 trans am that will be converted to ls1 soon.the electric on the 82 is in a bad shape,nothing works since the electric had a fire in the engine bay.so today i tok the harness out and its no hope for using it again.the only thing that seems to be good is the HVAC system.I have a complete salvage 98 firebird formula that will be my donorcar,I will use the engine and the tranny and the rear on it.I also have plans to use the 98 dash since my old in the 82 is cracked.So the best in this swap would be if i could use the complete harness from the 98 mod to my 82 mod.Is this possible to do witout too many problems?
Thanks guys...
Old Oct 5, 2008 | 01:44 PM
tpidude1's Avatar
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3,27
Re: 4th gen wiring swap
nobody here who knows?am I the first one who will do a complete wiring harness swap?
Old Oct 7, 2008 | 06:24 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
No...you arent. This question might have gotten more attention over in the conversions forum. There are also a few threads talking about complete wiring floating around.
It can be done. Its not the easiest thing in the world. But if you are using ALL of the wiring and most of the accessories from the LS1 car, you basically have to place the wiring from the LS1 in the thirdgen, and just start making things work one by one. There isnt a simple answer.
Do some more searching, and look up posts from a guy named shroom on here. I think his TA has most if not all of the wiring from an LS1 including dash, headlights/taillights etc.
J.
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
