1991 Firebird Starter Enable Relay----Help
Old Oct 5, 2008 | 08:58 AM
edyer1's Avatar
I have a 1991 Pontiac Firebird that will not crank. I replaced the Steering column and the starter and the car still won't crank. I have narrowed it down to the Starter Enable Relay but I have NO Idea were it's located.
Does anyone know where it is and what it looks like and can I get one at an auto parts store or do you have to get it from the dealer?
Old Oct 5, 2008 | 03:55 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 1991 Firebird Starter Enable Relay----Help
On the 91, I'd say it should be located close to the fusebox. Or if you don't find it there, it could be in the A-pillar, behind the kick panel (where the doorlock relay usually is). You can recognize it by its colors.
Make sure the relay is bad for real before you go buying a new one.
Hope this helps.
Lou
Street Lethal
Apr 30, 2019 12:14 PM
evan555222
Sep 20, 2016 02:51 AM
deracer
Apr 11, 2016 12:04 AM
wild1
Aug 27, 2015 09:01 AM
evan555222
Aug 22, 2015 07:14 PM
