adding power seats
adding power seats
I gave a 88 firebird base model and have just purchased new seats with a power drivers side and was wondering what is the best spot to wire it at? a picture would be great, also I would like it to be a constant on 12 volt source so i could adjust the seat even with the key not being in the car. Thanks for your help.
Car: 92 Trans Am Convertible
Engine: 5.0L
Re: adding power seats
I would suppose there are lots of ways to do it, I just grabbed off my Cig Lighter and ran a wire to the seat (Driver only - Passenger was not elect) I have been running that way for a good 10 months with no problem, and it is hot all the time so I can move the seat with the key out.
Engine: 5.0L
I have not burned yet,
and I did not change the fuse so the line is protected.
Changing the fuse to a higher amp fuse would eliminate the purpose of the fuse.
If you are concerned about using this as a source please read this thread
https://www.thirdgen.org/forums/elec...ght=seat+power
and I did not change the fuse so the line is protected.Changing the fuse to a higher amp fuse would eliminate the purpose of the fuse.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
i though the gauge of wire used for the cigarette lighter wasn't thick enough for what the motor draws and could cause a fire. was that not true?
That's VERY true !
Scooby Doo I'd put a small extingisher in your car if I were you !
Engine: 5.0L
I'll go back and check it out, but what is the purpose of the fuse, self destruct in an overload situation, I think I'll be fine.
Any ways if it starts to burn, I'd rather have marshmellows than an extinguisher
Engine: 5.0L
Now before you all get some hot dogs to throw on the fire I did some checking.
The cig lighter is on the ACC circuit.
The ACC circuit is protected by a 20 Amp Fuse, so every wire in that circuit can handle at least 20 Amps.
The Cig lighter pulls 6 amp draw.
The power seat pulls a 6 amp draw while moving, when you dead end it the draw jumps to 18.
So I think mine will stay the way it is and I'll leave the marshmellows at home.
So in closing
Legal disclaimer: your seat may be different than my and have a larger motor and draw more Amps, individual results may vary, not responsible for the actions of others.
So in closing
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
