Speedometer reads too fast
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
I have been using an 85mph cluster since I got my car a few months back. It had always read too fast: When I am doing 30, it says I'm doing 40. When I am actually doing 60, the speedo says I am doing 80. As speed increases, so does the gap between actual speed and read speed. Also, last night I did a swap for a 145 cluster with white overlays (went in perfectly) but now the speedo needle wiggles at constant speed to +/- 5mph (loose connection at the cluster maybe?) I don't know what gears are in the rear end and I am using stock IROC rims. Any help would be appreciated.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Speedometer reads too fast
You need to figure out what rear end gears you have and then get the correct speedo gears in the transmission to make your speedo read correctly.
What RPM is the engine turning while you're doing 60 MPH on the freeway in 4th gear?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following may provide some ideas:
https://www.thirdgen.org/forums/inte...eedo-woes.html
Here's how to determine what ratio the rear is (jerk the diff cover and look): numbers are stamped on the ring and pinion:
41 : 15 = 2.73
41 : 14 = 2.93
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
41 : 15 = 2.73
41 : 14 = 2.93
40 : 13 = 3.08
42 : 13 = 3.23
41 : 12 = 3.42
41 : 11 = 3.73
JamesC
Car: 1986 IROC-Z
Thanks very much guys, will update in a bit.
Car: 1986 IROC-Z
Stock tach says at 60mph (actual speed) in 4th gear the rpm's are at 2400rpm.
