86 TA HEADLAMP MOTOR RELAY LOCATIONS?
Old Oct 17, 2008 | 06:09 PM
sdanielstt's Avatar
COULD ANYONE HELP ME WITH THIS?
Guy's My son has a 85 TA.
His headlamps motors were not working so I tested each with direct power & they work. Also the lamps LITE UP with dash switch ON.
I now think the issue is definatly RELAY'S to the motors.
Can anyone tell me the location of the Relay or Relays OR ANYTHING ELSE THAT MIGHT CAUSE THIS PROBLEM? THx
__________________
Old Oct 17, 2008 | 09:09 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 86 TA HEADLAMP MOTOR RELAY LOCATIONS?
If someone knows what year GM switched to the single integrated relay module, please say so.
Now that I have that out of the way, IF the 85 doesn't have a relay on each headlight motor assembly, the relay module is located in a bracket on the firewall next to the relay block and the brake booster. It has 2 5-wire connectors running into it and has in big letters "GUIDE" on it.
Old Oct 18, 2008 | 03:10 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
__________________
one on each fender and one by the battery(most likely the problem one)
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Bert87
Aug 23, 2015 03:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
