air/fuel ratio gauge SIGNAL WIRE HELP.
Old Oct 19, 2008 | 03:16 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
guys....
i got an airfuel ratio guage but im havin a little touble. Im a noob at this and i dont no where i can tap into the signal wire to get a reading on the gauge.
Any thoughts?
thanks in advance
Old Oct 19, 2008 | 05:22 PM
1991ON20's's Avatar
Re: air/fuel ratio gauge SIGNAL WIRE HELP.
ECM port NUMBER D7.................i figured it out
Old Oct 19, 2008 | 05:44 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I hope you don't plan on using that for tuning for WOT as you're connecting into a narrowband sensor that will basically tell you nothing other than 14.7:1 AFR or something higher or lower.
Old Oct 20, 2008 | 12:53 AM
1991ON20's's Avatar
well....i dont have a wideband right now. i bought a narrowband A/F gauge back in the day and i wanted to simply hook it up. I plugged the signal wire into port D7 on the ecm and the gauge reads stoich ALL the time.
what did i do wrong?.....should i splice at the o2 instead?
WIDEBAND.....where would i plug that into?
Last edited by 1991ON20's; Oct 20, 2008 at 12:54 AM. Reason: Automerged Doublepost
Old Oct 20, 2008 | 10:44 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
A wideband would require a new O2 sensor, and something to tell you what it's reading. I believe all aftermarket widebands that you would use are 5 wire, not the 1,2,or 3 wire that's probably on your car.
Old Oct 20, 2008 | 11:00 AM
kennn's Avatar
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
Before we go any further, please describe your gauge. Is it a true wideband, or is it a narrowband simulator?
On the stock narrowband, the sensor detects absence or presence of oxygen. It can tell you rich or lean, but not how rich or how lean.
Aftermarket narrowband simulators take the readings and average over time to estimate the actual air/fuel ratio. This type can work off of the stock narrowband sensor.
A true wideband can tell what the ratio is in realtime. This type needs a new wideband sensor.
The kind of gauge you have will determine how you can hook up the sensor signal.
Old Oct 20, 2008 | 02:24 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I tapped mine into the wire off the O2 sensor.
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
