pass key problems...again
Old Oct 20, 2008 | 05:09 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
I have an 89 V6 camaro and I've had pass key problems this past august. when I last fixed it I used resistors to override or intercept the pass key so it wouldn't try to read the metal leaves that weren't reading correctly on the keyswitch. now I have the same symptoms again.
the syptoms are as follows:
fuel pump doesn't run
security light turns on for about 3 seconds when key is in run position
nothing happens when key goes to start position
security light doesn't come on again for another 5 minutes or so
is it possible that lower temperatures have altered the resistance of my fix enough that my car won't start? the resistors are not sodered on, I was actually going to sodder them sometime this week.
please help, I want to drive my car.
I have found that the security light now comes on and acts normally every time I turn the key. I'm thinking its the starter enable relay now, but I can't be sure. I don't have a test light to probe around with right now.
Old Oct 22, 2008 | 02:49 AM
RobSS1113's Avatar
Re: pass key problems...again
solder those resistors first !!
No fuel pump ? sounds like vats , hopefully an easy fix
Old Oct 22, 2008 | 10:01 AM
the fuel pump could be running actually. I live on a farm and some machinary has been running nonstop so maybe I'm just not hearing it. I tried jumping the starter enable relay to get the car cranking but its no use. this points to something in the starting/charging system.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
darwinprice
17
Oct 11, 2015 11:51 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
