Fuel pump wiring schematic
Old Oct 23, 2008 | 08:43 AM
1bad66ss's Avatar
Car: 66 Chevy II SS/89 iroc
Engine: 355/305
Transmission: 350 Turbo/T5
Axle/Gears: 3.08 posi
Hi guys, One problem resolved, vats bypassed thanks to the great help from the guys here. Next problem, is the fuel pump; if I'm understanding the wiring schematic found herehttp://www.autozone.com/az/cds/en_us...rInfoPages.htm
the orange wire should be hot 12v and the tan/wht at the pump should have 12v when the relays are energized? At the pump connection I had 8.75v, so I assume I need to back track to the relays and check voltage. This car has sat a few years so I'm not sure the pump is even any good.
From what I've read the relays are located on the drivers side fire wall (89 iroc) second one in from the drivers fender?
Thanks in advance for the help.
Old Oct 25, 2008 | 11:28 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: Fuel pump wiring schematic
i had no clue autozone had wiring diagrams they detail more than a haynes manual, if id known that i could have saved my 20 bucks.
Old Oct 27, 2008 | 08:19 AM
1bad66ss's Avatar
Engine: 355/305
Yeah I ran across that site after searching for some info I was looking for. Although it's good it lacks some of the wires, which makes it a little harder to figure out some things.
Old Oct 27, 2008 | 09:27 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
http://www.austinthirdgen.org/mkport...ta_sensors.jpg
Hope this helps.
Lou
Old Nov 14, 2012 | 09:49 PM
don6504's Avatar
bought an 87 lt camero with 305 carburatored. The person who had it before put a new mechanical fuel pump on it and the car runs but while it's running it feels like the fuel line coming from the tank is surging. Is there an electric pump in the tank and it seems like the tank is pressurizing.
Old Nov 15, 2012 | 05:37 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by don6504
Is there an electric pump in the tank .
Depends if the PO removed the stock elec pump from the tank when installing the mech pump
Depends what the PO did with the stock vent lines off the tank , he may have sealed them so the tank has no vent
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
