vats
Old Nov 8, 2008 | 08:03 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
vats
anyone know what color the wires are on the start enable relay in a 91 z28 5 speed? also i am not gettin any power to the clutch safety switch. what would cause that? a vats problem?
Old Nov 8, 2008 | 10:45 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: vats
use the search function a little and im sure you will find what you need someone has a complete tech article on soldering in a resistor on the vats system even lists the key codes and how to ohm out your resistor pellet in your ignition key.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
