Pioneer HU no memory and rear speakers
Old Nov 10, 2008 | 11:55 AM
Jollyrojer's Avatar
Car: 89 formula firebird
Engine: 305 tbi
Transmission: blown 700r4
Axle/Gears: 3.43
Wired as such With the HU colors first then the car colors
Yellow to Red
Black to Black
White black to Grey
White to Tan grey
Grey to Light green white
Grey black to Dark green and white
Red to Orange
Purple black to Dark blue
Purple to Light Blue
Green to Yellow white
Green black to Brown white
with Orange and white and Blue and white empty on the HU.
any suggestions on why the HU is keeping no memory and ive got 0 sound from the rear speakers?
Old Nov 10, 2008 | 12:32 PM
thirdgenfcarnut's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Axle/Gears: stock 3.23
Re: Pioneer HU no memory and rear speakers
Yellow on the Pioneer hdu is the battery lead and should go to the orange in the car, which is hot-at-all-times. The red on the Pioneer hdu should go to switched power (hot-in-acc/run) which is usually yellow in the thirdgen cars. As for the rear speakers, check for a short or blown speakers. Disconnect the rear speaker leads from the car and connect directly from hdu to known good speaker. If you get sound, try the rear speakers directly to the hdu. If they work, then you need to run new wires to the back. Let me know if you need any more help
Old Nov 11, 2008 | 07:39 AM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
typical base model stereo non delco-bose
display on signal-yellow from radio fuse 10amp in the fuse panel clock power-orange from acc fuse 20 amp in the fuse panel
on output-pink POWER ANTENNA SYSTEM
dim signal-Brown INTERIOR LIGHTS SYSTEM
panel light-Gray INTERIOR LIGHTS SYSTEM
RT front speaker-LT green
RT front speaker-DK green
LT front speaker-TAN
LT front speaker-Gray
LT rear speaker-Brown
LT rear speaker-Yellow
RT-rear speaker-DK blue
RT rear speaker-LT blue
Ground-Black
Reddeath210
Oct 6, 2015 08:20 AM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
zayne0
Aug 24, 2015 07:22 PM
89lsc
Aug 14, 2015 04:58 PM
