Red led on firewall???
Old Nov 10, 2008 | 08:28 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Ok so my girlfriend got a 1987 T/A and we noticed a little red LED that blinks occasionally while the car is running. Its located on the top right hand side of the firewall. Anybody know what this could be? sorry no pics
Old Nov 10, 2008 | 08:45 PM
Stephen's Avatar
Car: 87 GTA
Re: Red led on firewall???
In the engine compartment?
Old Nov 10, 2008 | 08:53 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Can you follow any wiring from it? My guess is a security module of some sort.
Old Nov 10, 2008 | 09:11 PM
Car: 1988 Firebird
Well its to late to go out and look at it tonight, but we noticed a red wire (that has an inline fuse) near the battery that was disconnected so we attached it to the positive side of the battery and a little red led attached to the firewall above like the master cylinder started blinking. I flashes when you first start the car, then it will stop and flash a couple of quick flashes every now and then while the cars running. When you turn off the car it flashes for a few moments then stops.
Old Nov 10, 2008 | 10:10 PM
Stephen's Avatar
Car: 87 GTA
Definitely nothing OEM...Sounds more like a half un-installed alarm system indicator light, that was left behind.
Old Nov 11, 2008 | 11:55 AM
yeah low's Avatar
could be a lojack, or a GPS tracker of some sort!!! Oh goody!
If it is a GPS tracker, can I hab it? I'll pay shipping... Seriously!
:biggrin:
/YL
Old Nov 11, 2008 | 03:34 PM
James76's Avatar
Car: 1984 Camaro Sport Coupe
Engine: 2.8l v6 soon to be 350
Transmission: auto
definitely an aftermarket alarm light. The reason it blinks after it starts most likely is its flashing a code for whatever last set the alarm off. If you have no alarm remotes check up under your dash to see if anything looks aftermarket.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
Dragonsys
Sep 25, 2015 03:51 PM
