starter..extra ground?
Old Nov 18, 2008 | 06:04 AM
dewitty's Avatar
i noticed when i changed starters that there was an extra little green screw on the case where a ground would hook up...never seen one before..would this cause electrical problems if not hooked up?
Old Nov 18, 2008 | 09:26 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: starter..extra ground?
No need for that extra ground. The starter is very well grounded by the two huge bolts that hold it to the block.
You're good.
Lou
Old Nov 18, 2008 | 11:37 AM
HoodsBadBowTie's Avatar
Car: '83 T/A, '83 Firebird
Engine: Carb 350SB. Carb 305SB
Transmission: 700R4. 700R4
Yea is should just be a ground but like stated up above its pretty damn well grounded already.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
