im gonna try it again
Old Nov 18, 2008 | 01:17 PM
dewitty's Avatar
my 91 formula has no power to the chassis..well the windows work...it starts and runs good..i checked all the fusible links i could find..i checked the wire on the starter..no fuses are blown...i put in a new headlight switch...which made it work for like 10 secs...but when i switched on the headlights it all went out again... im not sure a relay would control everything like that...can you test a relay?the headlights wont even pop up no gauge lights no dome light no power locks
Old Nov 18, 2008 | 02:18 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: im gonna try it again
Could be the headlight high/low beam switch, or gauge dimmer switch.
Old Nov 18, 2008 | 03:19 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
MY '82 CROSSFIRE HAS 3 GROUND STRAPS. ONE WENT TO THE FUEL FILTER BRACKET, ONE TO THE EXHAUST MANIFOLD, AND ONE TO THE BACK OF THE BLOCK.
92projectcamaro
Dec 8, 2015 12:25 AM
Zane Story
Oct 8, 2015 12:40 PM
91 SrS
Oct 7, 2015 04:32 PM
gmoutdoorsman
Oct 3, 2015 11:42 PM
Vincent135
Sep 28, 2015 10:50 PM
