Heater not working
Old Nov 21, 2008 | 09:26 AM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
Heater not working
I have a heater problem it blows heat and all but but it wont switch from vent its got vaccuum and all that jazz but it wont change from off or vents.
Old Nov 21, 2008 | 09:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Heater not working
Sorry, it's early and I'm a bit dull this morning. If you only have defrost, which the the default setting, you have a vac leak.
JamesC
Old Nov 21, 2008 | 10:40 AM
Car: 84 camaro z28
Engine: 5.7 carbed
JamesC
But its not its stuck on vents not defrost
Old Nov 21, 2008 | 12:01 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
If you have a vacuum leak it will not change from the last setting it was in before it lost vacuum.
Old Nov 21, 2008 | 12:25 PM
JamesC's Avatar
As I mention above, it'll default to defrost. Perhaps, 84, you should pull the HVAC and take a peek.
JamesC
Old Nov 21, 2008 | 10:58 PM
Car: 84 camaro z28
Engine: 5.7 carbed
i tried that its got good vaccum and a new donut on it so thats got me puzzled.
Old Nov 22, 2008 | 06:38 AM
JamesC's Avatar
Donut?
JamesC
Old Nov 24, 2008 | 08:02 AM
Car: 84 camaro z28
Engine: 5.7 carbed
ok my bad its the round black thing on the heater control with silver metal tabs that changes the vents with vaccum. Hooks up near the vaccum line.
Old Nov 24, 2008 | 12:36 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
With the car running do you have vacuum at the rear of the controll head? There should be one plastic hose (black) that runs from a vacuum sorce and routes to the inside of the car behind the heater / A/C controll head. Here it becomes multiple very short vacuum lines and are different colors. Depending on where you have the slider selected (heat, vents, defrost etc) the controll head will route the vacuum sorce to move the main door and route the air where selected. If you are not able to controll the vents it is either a vacuum leak, or the lever that controlls the Door is jammed. Usually the problem can be traced down to a vacuum leak.
Old Nov 24, 2008 | 08:26 PM
Car: 84 camaro z28
Engine: 5.7 carbed
its got good vaccum at the black hose but im not sure really how to get a testers on the other ones
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
