Electrical system is dead......help....
Old Nov 21, 2008 | 10:27 AM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
I have a 1986 V6 Firebird.
Yesterday when I tried to start it, it started to turn over and then just stopped.
It seems that all electrical power is gone. No lights, nothing.
I just started charging the battery, but it seems to still have a charge.
Am I right in assuming I may have blown one of the fusable links?
I dont have a breaker box in this car like I do in my 4th gen, so what do I look for?
Help?
Old Nov 21, 2008 | 12:09 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Re: Electrical system is dead......help....
Start by making sure the battery leads are hooked up tight to the battery and are corrosion free.
Old Nov 21, 2008 | 02:52 PM
Engine: 2.8L - 6.3L
checked connections, no corrosion.
Old Nov 21, 2008 | 03:05 PM
kcb37's Avatar
You should have a fuse block.
Unless it's differnt then my Camaro, it under the dash on the driverside. On one side or the other of the steering colum.
How old are your battery cables?
Wouldn't hurt to start checking fuseable links.
Is your battery charged?
Do you have power to the starter?
Old Nov 21, 2008 | 04:38 PM
Engine: 2.8L - 6.3L
No power to anything, as if I pulled the battery.
Old Nov 21, 2008 | 05:22 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
check the fusible links at the starter if you have no power here (use a test light) then start pulling on the wires slightly...if you blew a fusible link then the wire will pull appart easly for all that is left is the insulation and the wire inside would be melted. If the fusible links are okay then start tracing the wire backwards and find out where the power is lost.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
Formula8r89
Sep 22, 2015 04:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
