Battery ground connection...Help please
Old Nov 21, 2008 | 04:55 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
Ok when i rebuild my enigine i painted the block and my question is where the battery ground cable hooks up is on the side of the block, and my starter is acting like it doesnt want to engage fully somtimes. Do you think that the paint is giving it a bad connection?
Old Nov 21, 2008 | 05:17 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
Re: Battery ground connection...Help please
It could be..Disconect the cable and sand down to bare metal and re-attach. It is important to have good grounds. Could also be that it is not shimed properly as well.
Old Nov 21, 2008 | 05:27 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
what needs to be shimmed?
Old Nov 21, 2008 | 05:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need to sand, just run a tap down the threads of the bolt hole.
Old Nov 21, 2008 | 05:31 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
tap? lol. i'm clueless
Old Nov 21, 2008 | 05:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a tap is the tool that makes the threads in a hole. A die is the tool that makes threads on a bolt.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
camarohelp
Sep 22, 2015 03:19 PM
eustodp
Sep 20, 2015 05:09 PM
gta892000
Sep 16, 2015 12:37 AM
