Digital Gauge questions
Old Nov 27, 2008 | 10:53 PM
speedfreakracin's Avatar
Hello everyone, I did a search but didn't come up with too much information, first off I swapped a 350 TPI engine, harness, and trans from a 1989 Firebird Forumla into another vehicle (non electronic gauges). I know I cannot fabricate the old cluster to work, does anyone know of any good electronic gauges that work with the stock VSS signal and also anything that would be good to work with oil pressure, coolant temp etc also. The dash would definitely be custom.
Old Nov 28, 2008 | 12:56 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Digital Gauge questions
I would use something from dakota digital or nordiskog. (Autometer is making something in digital, also I believe)
Welcome to TGO!
Good luck!
Old Nov 28, 2008 | 03:24 PM
Next question, is there any way to retain the manual speedometer cable set up but still have a VSS signal to the PCM (any previous years using a dual setup?). Assuming the VSS signal is used for cruise control and TCC application only(note: will not be using cruise control).
Frozer!!!
Jan 19, 2024 04:55 PM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
