oil pressure gauge
Old Dec 3, 2008 | 07:02 PM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
oil pressure gauge
how do i tell if my gauge is shot or that my oil pressure is through the roof? fall down to zero when off and moves all the way up when started
Old Dec 4, 2008 | 06:51 AM
EvilCartman's Avatar
Car: '82 Z28
Re: oil pressure gauge
Does it go all the way up with the engine not running? Make sure the wire is still connected to the oil pressure sending unit.
Old Dec 4, 2008 | 07:23 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
sounds like you have a bad oil oil press. sensor . a common enough problem on 3rd gens. . located above oil filter , not too bad to replace . be careful of old brittle plastic elect. connector on sensor . good luck .
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
