Voltage Drop Cranking Car
Old Dec 8, 2008 | 08:52 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I've searched but think I have al my bases covered so I'm looking for other possible electrical issues I can deal with...
Battery shows normal voltage (a little over 12v with the car off) but when I crank it with my starter button it drops to 8v!
All the engine compartment wiring is "custom" and for the most part I left the interior and dash wiring alone (except for removing the ECM).
Battery is relocated to the rear.
I am running a 1/0 welding wire from the battery to my battery cutoff switch.
1/0 welding wire from the batt cutoff switch to the starter.
The alternator charging lead is lengthened and ran to the "switched" side of the cutoff switch (but kept the stock fusible links and fuse tied in with it).
I have my battery grounded to the frame (1/0 welding wire), engine grounded to the frame (4ga ground strap), and battery grounded directly to the engine (4ga wire).
What other wiring could cause this? I have not started the car due to a fresh rebuild, the battery is a 4 year old Optima pulled from my Corvette but I cannot rule anything out...
Old Dec 8, 2008 | 01:28 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Re: Voltage Drop Cranking Car
Well, I charged the Optima but still am having some gremlins.
I guess I need a mini-starter and a new battery for starters and then I need to go from there.
I am thinking a need to revamp my alternator charging wire setup and find out why my DVM goes crazy inside the engine bay.
Old Dec 8, 2008 | 02:40 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I'm pretty sure I have double checked them. The battery to frame, engine to frame, and batt to engine grounds are all A+. I have removed the pass side harness to the ECM so only have another ground to the drivers head that runs to the drivers side bulkhead. If I'm missing anything I wouldn't know where to look.
Seriously though, whenever I place the DVM over the engine bay it starts flickering like crazy. It will flicker any number (say 19.2 volts for a split second the 2.3 etc. maybe a tenth of a second between flickers). This only happens when the engine is running so it tells me it has to be from the alt creating some electric field in the air.
Old Dec 9, 2008 | 10:18 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Yea this sucks.
Still need advise on what would be going on here. Buying a new battery and high-torque starter to hopefully fix the issue but I need ideas.
Old Dec 9, 2008 | 10:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Much more likely it's EMI from the ignition, not the alternator.
Old Dec 9, 2008 | 12:13 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Thanks guys. I just spoke with a friend who oens a business rebuilding alternators and starters (where I got the current alt and starter from) and he thinks it would be ignition related as well.
Is there anything I can do to combat this problem or is this inherent with the ignition I am running?
MSD Superconductor 8mm wires (cut to fit)
Procomp HEI large cap dizzy (50 volt coil)
NGK resistor plugs (same result with Autolite resistors as well)
Formerly small cap TPI setup. I have the pink wire supplying 12v to the dizzy and the white wire hooked up to the tach.
Would any of the other wires previously used on the ECM controlled ignition cause this?
Old Dec 10, 2008 | 02:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Get a better DMM.
Old Dec 10, 2008 | 02:59 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Picked up an analog meter today from Radio Shack. Decided to re-vamp all my wiring a little bit, however. With the new adequate starter, good battery, and new wiring this thing should scream.
Old Dec 11, 2008 | 07:53 PM
cmgrinn's Avatar
Car: 91 Z28
Engine: 5.7 L98
Transmission: 700r-4
Axle/Gears: 3.43
Sounds like your starter is drawing to many amps causing your voltage drop. especially if you got higher compression. Wouldn't hurt to have a high torque starter anyway. good luck.
Old Dec 11, 2008 | 09:41 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
The battery wasn't in the best of shape so hopefully one better off will help. The battery cut off switch was rated at 20 continuous amps and 125 surge amps so that was a huge bottle neck (I can't believe it lasted this long!!!), and the stock style starter was a huge issue.
I received my new starter and went to put it on only to find out the mounting block hits the oil pan rails
Now I have to get around that somehow.
Old Sep 6, 2009 | 08:23 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Little update...
Got a new Summit min-starter and decent sized working battery from a friend. Still receiving a voltage drop down to around 8 volts at the solenoid when cranking.
Also, showing only 12.5 volts with the car running. Alt bench tested fine, battery bench tested fine, both wires going into pigtail showing voltage.
I'm stumped.
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
Kaweh
Aug 9, 2015 02:54 PM
