89 export km/h speedo convert to 1LE panel
Old Dec 8, 2008 | 02:36 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
hi guys,
i was looking at converting my export version formula's "metric" instrument cluster to one of these 140mph / 8krpm L98 (1LE?) ones. would i need any converters or change any other kind of electronic stuff to put that in and get correct readings?
i would really love the greater ranges of this cluster
thanks in advance!
ownor
Old Dec 8, 2008 | 07:05 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 89 export km/h speedo convert to 1LE panel
Assuming that all clusters are similar ( CABLE vs. Electric ) It should be plug and play !!
Old Dec 10, 2008 | 01:45 PM
ownor's Avatar
Engine: LS1 / L03
thank you John. any other thoughts or opinions on this?
i think 87-up everything was converted to VSS/electrical.
greetz
anyone knows how i could "set" the milage on the cluster i will be getting? my formula is about 70kmls and this cluster has about 150kmls on it. what can i do?
Old Dec 12, 2008 | 04:20 AM
ownor's Avatar
Engine: LS1 / L03
sorry for the double post but i was trying to bump it to the top because this is URGENT - thanks in advance!
Old Dec 14, 2008 | 05:00 AM
ownor's Avatar
Engine: LS1 / L03
sorry i still need this info >.< bump
GTAman
Jul 3, 2024 07:29 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
andy74
Sep 3, 2015 08:41 AM
