Crazy Blinking DVM...Alternator Magnetic Field???
Old Dec 9, 2008 | 10:16 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
This is very strange and each individual I have spoken with about the issue is pretty much clueless.
My DVM will blink like crazy when my car is running. It will blink say 19.x for just a split second then 2.x then 14.x ten 7.x get the idea?
Its driving me mad and has to stem from the alternator since it only does it with the car running. I have tried two seemingly good alternators (tested at AutoZone) to no avail.
Heres the kicker. It will do it without the DVM actually touching anything!!! When placed over the engine compartment it will do this and when just outside the compartment it stops?!
It does not do this with any other vehicle and the battery is good in the DVM. Is this possibly a wiring issue I am not aware of? 1991 Camaro.
Old Dec 10, 2008 | 07:03 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I THINK, THEREFORE I BLINK
Possibly the ignition is causing that.
On my dirt car we’re using solid core wires and plugs.
Therefore when taking voltage measurements we use an analog meter.
Happy Racing!
- Race clean!. . . . . . . . . Do it on dirt! -
Old Dec 10, 2008 | 11:15 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Re: Crazy Blinking DVM...Alternator Magnetic Field???
Nice caption
I think so too now, however, don't know if there is a way to combat the problem or deal with it.
Its a large cap generic HEI dizzy
MSD Superconductor wires
NGK resistor plugs
My MSD 6AL is awaiting hookup until I can sort all of the other bugs out.
Will this cause some crazy feedback in my stereo as well??
Old Dec 11, 2008 | 07:47 AM
NINÅ's Avatar
Transmission: 765R4
THE SPARKS! MUSICAL GROUP OR IGNITION?
If you maintain resistor plugs and suppression wires your stereo will be OK.
Happy Racing!
- Race Clean!. . . . . . . . . . . Do It On Dirt! -
Pac J
May 17, 2020 10:44 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
64Chief
Sep 12, 2015 08:05 AM
