Blower motor promlem
Old Dec 12, 2008 | 08:00 PM
J_Dubb44's Avatar
Car: 1984 Pontiac Trans Am
I have an 84 Trans am. The other night I parked it and the blower motor was working fine. Then it sat for a bit and when I got back in the blower motor didnt work. The heater and the selector switch is working, theres just no air being moved. Ive tested the blower motor itself and it works. Ive tested the blower motor relay and it works. I tested the fuse block and it works as well as no fuses were blown. Im running out of ideas so any input would be great.
Old Dec 15, 2008 | 03:24 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: Blower motor promlem
So you tested everything individually and it all worked. When you tested the motor itself did you just apply your own power and ground? A lot of times the ground wire going to the metal housing of the motor becomes loose or a bad connection. If you have power at the wire at the motor connector, make sure the motor housing is grounded.
Old Dec 15, 2008 | 04:37 PM
T4Revan's Avatar
Car: 88 Formula, 89 Firebird.
Engine: 355 V8, 2.8L V6
Ran into the same issue 2 weeks ago. My heat and a/c stopped working but the motor would still spin when I removed it and tested it. Turns out the motor was the problem. It was pushing air, but not enough to feel it in the car. Go replace the motor, it's only $25 with a lifetime warranty at Autozone.
Old Dec 16, 2008 | 08:44 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
DON'T BLOW THE PROBLEM OUT OF PROPORTION
What he said because the commutator and brushes wear out in such a way the symptoms will include the motor SOMETIMES working.
Happy Racing!
If people drove any slower they’d be going backwards
Old Dec 16, 2008 | 10:45 AM
J_Dubb44's Avatar
But I replaced the motor in february this year. Plus Im not getting any power from the wire going to the motor. But if I jump from the blower motor fuse straight to the motor it works. So it has to be something in between, but I replaced the switch and im not sure what else there is.
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
