What starter?
What starter?
I'm not sure what count the flywheel is but
The motor and trans cam out of a 72 nova - 350/th350. I used a V6 2.8 starter for awhile but finally died. I would guess it's a 168 tooth flywheel (2.8 starter is a 148 tooth) and the block is drilled for straight and staggered bolted starters. I also have Hooker Supercomp long tubes. Trying not to spend 200+ on a starter.
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Re: What starter?
I believe you get what you pay for. Having the longtubes, I'm assuming you'd need a mini-starter. I've had excellent results with the XS series from Powermaster. I think it was somewhere near $200 though.
Re: What starter?
Yea I actually don't mind spending the money but didn't want everyone to tell me get this $295 starter. The car is on a budget (well trying to be). Is there anyway other then counting the teeth to find out what tooth it is (installed in the car with the trans)?
Gunner242
Dec 25, 2015 04:49 PM
