battery relocation - where to run (+) to starter
Old Dec 17, 2008 | 10:57 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Hi, I've mounted my battery with a kill switch and am wondering where you all ran your positive wire to get it back up to the starter. Particularly, did you run it along the outer rail underneath the car, or did you run it through the interior and firewall? I want to keep my wire protected from the outside as much as possible, so I ran it up the passenger side interior, and was considering drilling a hole in the firewall for it. I'm just wondering what most people do and if there's any pros or cons to either choice.
Also, I need to run alternator wire back to the kill switch if I want the kill switch to work properly, correct? Thanks in advance for the help.
Old Dec 17, 2008 | 11:11 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: battery relocation - where to run (+) to starter
Wanting to relocate my battery,so.... subscribe.I think I`ve read alot of guys just run it under the car.
Old Dec 17, 2008 | 11:58 PM
luke4907's Avatar
Engine: TPI350
ya but even that it looks like to me it'd be real close to the y-pipe/exhaust since mine's running up the passenger side. I was thinking through the firewall above where the passenger left foot would go. Seemed like a good spot, then again I don't have my headers in right now...
Old Dec 19, 2008 | 06:12 PM
luke4907's Avatar
Engine: TPI350
ttt... hoping someone has some pics too.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
