89 FIREBIRD FORMULA lights help needed
I got 2 problems with my car right now:
1) the lights dont go down when i press the button...they turn off but stay in the UP position... i can hear the noise of the motors working but they just dont go down....last week they would go down after like 5 tries...but now they dont go down at all...this has been happening for about a week
2) This just started today...the second problem (might be connected to the 1st)...the beeping noise (when you turn the car off...to remind you to turn your lights off) beeps all the time...even when the car is on...i cant get it to stop...even when i turn them off...the thing beeps...the only way it shuts is when i turn the car off...its really anoying
ANY HELP!!!
ANY HELP!!!
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: 89 FIREBIRD FORMULA lights help needed
One thing I can say is if your door pin switch is grounded, thinking that the door is always open, that would cause the beeping to remain on whether the lights are on or off. Probably not the problem, but something to check. I'm guessing you don't have a problem with your dome light staying on.
Axle/Gears: 9-bolt/3.45
This should solve your headlight problem:
http://www.top-downsolutions.com/pro...products_id=87
The repair kit comes with detailed instructions, helping to make the repairs as simple as possible. But if you have any questions, Lon, the owner of TDS is pretty easy to find. He's a moderator here on TGO(lonsal), a TGO sponsor, and an excellent vender. In fact, he probably just hasn't seen your post yet, or he'd have probably already replied to your topic.
MANY 'bird owners here on this site have already used this repair kit, including myself, and we can all tell you that it works well. The up-and-down motion of your headlights will be as solid as when the car was brand new.
theshackle
Mar 5, 2017 06:37 PM
