dash light problem?? please help
Old Dec 21, 2008 | 11:04 PM
Guest
Guest
Posts: n/a
i have a 87 iroc-z 5.7 tpi auto all stock when i turn my headlights on my gauges go off the chart well just the tach, volts,and oil. if i turn the dash lights off then everything goes back to normal except i have no dash lights?? i have replaced the headlight switch thinking this was the problem but it changed nothing im lost please any help
Old Dec 22, 2008 | 10:44 AM
Guest
Guest
Posts: n/a
Re: dash light problem?? please help
bump
Old Dec 22, 2008 | 11:12 AM
Guest
Guest
Posts: n/a
bump
Old Dec 22, 2008 | 11:57 AM
Guest
Guest
Posts: n/a
bump
Old Dec 22, 2008 | 12:36 PM
Guest
Guest
Posts: n/a
bump any help please
Old Dec 22, 2008 | 12:48 PM
arodgers07's Avatar
Car: 85 IROC-Z
i got the same problem with my 85 iroc except my right turn signal light comes on also??? ive replaced the cluster assembly and light switch but it didnt change anything. ima start tracing back wires really soon so ill let u kno if i find anything.
Old Dec 22, 2008 | 05:15 PM
Guest
Guest
Posts: n/a
bump
Old Dec 22, 2008 | 05:46 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
sounds like you may need a new gauge pack, they are pretty cheap on e-bay, look on here also.
atleast thats what i would repace
Old Dec 22, 2008 | 06:30 PM
Guest
Guest
Posts: n/a
how cheap? can u get them new?
Old Dec 22, 2008 | 07:23 PM
89RS_82Z's Avatar
cant get them new, just make sure you get one that has been tested, if its going on a 89 or older get the cheap 85 MPH speedo and just swap your higher speedo out in it, as long as you use the board and housing from the other gauge you should be ok
but i woluld like to see someone second my idea, i think that should fix it but not 100% sure
you can get an 80mph one for prob somewhere around 20
Old Dec 23, 2008 | 08:23 AM
Guest
Guest
Posts: n/a
i need the 145mph one because mine is broke
Old Dec 23, 2008 | 05:26 PM
89RS_82Z's Avatar
well thats gonna cost ya, you may want to go with a 115 they are a little cheaper
good luck with it
Old Jan 10, 2009 | 10:20 AM
85Iroczz28's Avatar
Car: yellow 1985 iroc z28
Did you ever find out the problem with your gauges mine are doing the same exact thing as yours i just boaght my car and do not know how to fix. if you did please let me know and if i find anything out i will be sure to post it on here for everyone so please lets help eachother.
Thanks Rodney
Old Mar 7, 2009 | 06:52 AM
85Iroczz28's Avatar
I have been working on my car for along time trying to figure out the problem, a guy posted another message up about the same problem and someone sent him a picture of the gauge cluster witch had been modified with a ground comeing from the right turn signal to any ground point i tried evrything finally i tried this and i took a wire from the right turn signal and grounded it to the bottom of my steering column and everything works great no problems. I will try posting a picture here soon good luck.
Old Mar 10, 2009 | 02:18 PM
Guest
Guest
Posts: n/a
oh please get me some pics or a link cause this is still driving me crazy. thanks
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
