too high no low
Old Dec 23, 2008 | 05:35 PM
Grizzle B's Avatar
Car: 1984 Camaro Z28
Engine: '92 LT1
Transmission: 700R-4
Axle/Gears: 3.73 factory posi. disc brakes
too high no low
my highbeams work but my lowbeams don't. what is going on and how do I fix it?
Old Dec 23, 2008 | 05:53 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: too high no low
need to see if your getting voltage to the bulbs, if you are replace the headlights
if not then its prob your multi function switch
Old Dec 23, 2008 | 10:59 PM
Grizzle B's Avatar
Engine: '92 LT1
Re: too high no low
im getting volt to the bulbs where is the multi function switch at?
Old Dec 24, 2008 | 01:49 PM
89RS_82Z's Avatar
Re: too high no low
if your gettting voltage to the bulbs then its your bulbs or its the ground for the lights, could be the connector also, do the low beams come on when you turn the highs on????
anyway the multi funct is in the stering colum thats, it what the turn sig lever is hooked into, but if you volts at the plug than its not the MFS
Old Dec 24, 2008 | 01:54 PM
89RS_82Z's Avatar
Re: too high no low
read into this
https://www.thirdgen.org/headlightupgrade
the low beam has 2 filiments in it one is on at low beam the other comes on when your seperate high beam (your inside 2) comes on, its like to suplement the dead area between the high beam light patern and the front of the car (or something like that) if they come on then it just happens to be both of your lows are blown, i suggest replaceing the with silverstars and doing the upgrade on the link i gave you
db057
Apr 28, 2019 07:45 AM
Linson
Sep 21, 2015 01:08 PM
Stryker412
Sep 7, 2015 09:11 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
