Tach signal?
Old Dec 28, 2008 | 07:20 PM
mfaust's Avatar
Car: 88' Trans-AM WS6
Tach signal?
I have read many of the tach related post here, but I can not find what signal is driving my tach.
I have a 88 Trans-am 305 TPI. I have heard 4 pulses / rev at 12 vdc, can anyone confirm this - I do not have a o-scope
Old Dec 28, 2008 | 11:36 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Tach signal?
You are right, 4 pulses per crank revolution (8 sparks per camshaft revolution). The pulse is nice and square 12V with some kickback from the coil so make sure you use a good filter if you want to use the signal for anything besides a tach.
It should be the white wire behind your instrument cluster.
Hope this helps.
Lou
Old Dec 29, 2008 | 05:04 PM
mfaust's Avatar
Re: Tach signal?
If it is a dc signal, what kind of kickback are you referring to, I am making a digital cluster with a lcd and all kinds of neat stuff.
Do you have any suggestions for a filter?
Old Dec 30, 2008 | 09:42 AM
BigBadLou's Avatar
Engine: TPI
Re: Tach signal?
When the coil ground is disconnected (rising edge of the pulse), the coil produces a high-voltage spike. You need to filter that out. There are numerous filters online if you search, but I always use a opto-element anyway so that takes care of it.
Enjoy your project, I know I WOUL! :-D
Lou
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
