Can't connect neg cable
Old Jan 2, 2009 | 04:21 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
During the winter I pulled my motor to fix leak issues. I dropped it back in and have hooked up everything (everything was clearly labeled.) Now, when I try to connect the negative cable to the battery it sparks and heats the bolt if I leave it touching for just a second. The neg cable grounds between the block and alt/ps bracket and the smaller wire off the neg cable was untouched from where it was bolted previously. Obviously I'm missing something, but what would be cause this? Is it a missing ground issue, or could it be something on the positive side. I replaced the starter. Would incorrectly hooking up that (it's not complicated obviously) cause this. It's getting dark and cold, so I stopped for the night to ponder this dilemma. Thanks
Kevin
Old Jan 2, 2009 | 04:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can't connect neg cable
Something on the positive circuit is shorted to ground.
Old Jan 2, 2009 | 04:37 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Yeah - I think I erred with the starter connections.
Old Jan 2, 2009 | 09:22 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
I noticed I reconnected the round connector of the positive lead between the accessory bracket and the block, instead of on the outside of the acc bracket. Would that be the something on the positive circuit shorted to ground? The connector broke as I was removing it, so I have to splice in a new one. As it was not connected to anything the negative terminal was no longer shooting sparks when I touched the negative cable to it.
Old Jan 2, 2009 | 09:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The positive lead doesn't go to either of those locations.
Old Jan 2, 2009 | 09:51 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
From the positive battery terminal, the wire splits, the thicker of the two (without the fusible link) runs along the front sway bar to the passenger side, where it ultimately ends in an eye connector at the bottom torq bolt of the A/C & smog pump pulley bracket.
Old Jan 2, 2009 | 09:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No it doesn't. Connect it there and you'll just keep melting things.
Old Jan 2, 2009 | 10:25 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
I'm not making it up. It's been connected there for 20 years. But OK. Let's assume I'm wrong. Where would that eye connector (that just happens to be long enough and shaped perfectly to fit where I say it does) be connected if not there? But, you're right. It doesn't go there. Where does it go?
The picture is shot from underneath the car, looking up.
Old Jan 2, 2009 | 10:45 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
you can't connect the positive lead to any part of the chassis, this is ground, it doesn't go there. the positive lead goes to the starter/alternator.
Old Jan 2, 2009 | 10:48 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
You guys are correct. I'm a jackass. That has to go to the starter then?
wigmobile
Feb 26, 2025 02:56 PM
L0tuS
Oct 4, 2015 08:07 AM
abrilnelson89
Sep 17, 2015 10:41 AM
gta892000
Sep 16, 2015 12:37 AM
corey8084
Brakes
Sep 15, 2015 08:14 PM
