Horn reley location? 91 Firebird
Old Jan 2, 2009 | 09:27 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, I got a new horn in the car, as the original was gone. I found the wire, it's a common black on the drivers side, I put my meter on it, and had nothing so either my relay is no good, or the fuse is toast, where's it at? Thanks, KP.
EDIT: Relay, sorry, played too much pool this afternoon...
Old Jan 3, 2009 | 08:34 AM
Kevman's Avatar
Engine: 2004 LQ4
Re: Horn reley location? 91 Firebird
No one knows?
Old Jan 3, 2009 | 09:21 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Horn relay is in the convenience center with your hazard flasher and door chime. Under the dash, to the right of the steering wheel. You will need to remove the trim panel underneath the steering column.
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Stauf
Aug 24, 2015 08:31 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
