Convert Cable to VSS
Old Jan 2, 2009 | 10:23 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I need to convert Cable to VSS and did a search. I have seen that many people have actually just replaced a cable sensor to a VSS into their transmission. Although I would not mind that it will get a little expensive for my tastes. So I found this and I cannot figure out if this is going from cable to vss or vss to cable and which pulse I would need. I have a 1989 Camaro RS T-5 350. I am putting in a speedometer from a 1988 Formula 140 mph.
http://www.dakotadigital.com/index.c...rod/prd109.htm
The Sen-01-1 is what I am looking at.
Old Jan 3, 2009 | 03:35 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Convert Cable to VSS
That's one piece you'll need. I have one of those that came with the digital gauges I had made for my 92 RS. I already had the electronic VSS, so I didn't need the piece. It puts out 8K pulses per mile, your RS probably needs 2K or 4K per mile (my 89 305 TBI I'm pretty sure uses 2K, my 92 V6 is 4K per mile). You will probably need this piece to convert 8K to the proper count for your car.
http://www.dakotadigital.com/index.c...rod/prd126.htm
For shipping, you can have the VSS sender as I have no use for it. Shoot me a PM with shipping info and I'll find out how much it'll be.
I'll also make sure this thing fits my 89's tranny. I've had it for almost 4 years and it looks almost like the one pictured for Ford, but design may have changed since then.
Al
GTAman
Jul 3, 2024 07:29 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
92firebirdguy
Sep 10, 2015 10:33 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
