custom wiring plugs/harness
Old Jan 6, 2009 | 09:10 PM
jupetto's Avatar
I am relocating my front end wiring harness from where it goes from the drivers side firewall to the left front headlight assy.I have lengthened the harness so I can reroute it through the drivers side fender.what I want to do is replce the big factory plug on the end of this harness the normally plugs into the firewall. that end of the harness will go into the car in the door jam area and will plug into the int harness that is normally mounted on the firewall, which it is not now.
what I need are new connectors or plugs (male and female) that I can use to plug the front end harness into the int harness. this sounds like alot of work I know to relocate a harness, but I already relocated the engine harness inside the car and only about 3 single wires (oil pressure,water temp,alt) and the wiper motor wires are all that are visible now, so needless to say my engine bay is very clean in relation to wiring. this is the last harness I need to relocate, all I need are some electrical plugs to finish the job.
Jeremys87
Jul 14, 2022 09:08 PM
midge54
Sep 2, 2020 07:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
djmarch
Aug 19, 2015 12:07 PM
