Crazy Gauges PLEASE HELP.....
Old Jan 10, 2009 | 09:58 AM
85Iroczz28's Avatar
Car: yellow 1985 iroc z28
I just recently have baught a yellow 1985 iroc z28 with a 305 tpi engine with 77,000 original miles and i am the 2nd owner to it when i got it home everything worked great until i turned on the light's. When i did the voltage gauge and oil pressure dropped along with the RPM gauge if anybody knows anything about this or what i can do to fix it please let me know i have a receipt were the original owner boaght a new headlight switch so i wouldn't think it would be in that. I realy think that it is in the dash assembly but not sure if you know anything please tell me Thanks Rodney
Old Jan 11, 2009 | 12:12 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Re: Crazy Gauges PLEASE HELP.....
Check, clean, and lube the ground(s) and 12V connections under the hood.
Old Jan 14, 2009 | 11:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Did the eng slow down at the same time or sound like it wanted to stall.If so the oil pressure, voltage, RPMs would drop together as well.Could be the alternators not up to the task or maybe a short in the headlight wiring.
Pac J
May 17, 2020 10:44 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
