Putting the Dash back in, where do these plugs go??
Car: 1986 2.8 Camaro
Engine: TPI 350
Transmission: Tremec TKO
So I'm putting the dash back into my Camaro and I have found all of the electrical connections except for these four connectors, does anyone know where they go? The first three are coming out below the steering column, and the last one is coming out by the HVAC console.
Thanks...
http://good-times.webshots.com/photo...96822721oSCOCg
http://good-times.webshots.com/photo...96822721hvjMoa
http://good-times.webshots.com/photo...96822721WvlCnV
http://good-times.webshots.com/photo...96822721hkkZHF
Thanks...
Car: 83 Recaro TA/ 95 TA
Engine: 355 / LT4
Transmission: turbo 350 / 6 speed
Axle/Gears: 373 / not sure think same
Re: Putting the Dash back in, where do these plugs go??
did u change the dash or is it the origanal
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I think the 3rd pic is the wire for the cruise control. Its the wire coming from the turn signal lever. Should be coming out of the column under the dash. I think pic #2 is its mating plug but not forsure.
Engine: TPI 350
Well heres the thing, the car is originally an 86 SC, but after my 89 IROCZ got totalled out, I bought it back from the insurance company and totally stripped it down, and put it all into my 86 SC. So you could say that it is original since I swapped EVERYTHING over to the 86 car. When I swapped the dashes, I'm almost positive that those plugs (the first two) had specific homes. Now I cant remember where they go??
Thanks guys for your help...
pic 1 looks like it may be the dimmer switch, pi.s 2 and 3 are the cruise control plug them 2 together, not sure on the 4th one it may go to the hvac
