fuel pump relay
Old Jan 10, 2009 | 01:16 PM
chosen1's Avatar
Car: 86 Z-28
Engine: 305TPI
fuel pump relay
Which relay is for the fuel pump? There are two next to each other and also which wires do i jump to check relay? Any help would be appreciated as i need to sell my sons camaro. He won't be driving for at least 33 months.The car is a 90 rs 305 TBI.
Old Jan 10, 2009 | 01:28 PM
Blue-Z28's Avatar
Car: 86 IROC-Z
Engine: 305 tpi
Re: fuel pump relay
https://www.thirdgen.org/forums/atta...n-z-relays.jpg
Old Jan 10, 2009 | 01:58 PM
chosen1's Avatar
Car: 86 Z-28
Engine: 305TPI
Re: fuel pump relay
i appreciate the help,but that picture is just way too small for my old eyes.
Old Jan 10, 2009 | 05:36 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
Re: fuel pump relay
those are not the same locations on my car, that looks as if someone butchered theirs then took a pic. That's also a pic for a TPI I think, because I'm not sure what a TBI looks like.
if tbi is the same as tpi, all 3 relays are suppose to work for any 3, it doesn't matter what's plugged in where, supposedly.
Old Jan 10, 2009 | 06:48 PM
chosen1's Avatar
Car: 86 Z-28
Engine: 305TPI
Re: fuel pump relay
which wires do i bridge to check relay? and which of these is for the fuel pump?
Old Jan 10, 2009 | 07:51 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Re: fuel pump relay
thank god for a high quality picture lol
both relays are the same part number, try switching the plugs.
but I'm not sure which wires to jump.
Old Jan 10, 2009 | 10:30 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: fuel pump relay
Try this troubleshooting article: http://www.austinthirdgen.org/index.php?pid=35
Hope this helps.
Lou
Old Jan 13, 2009 | 02:46 PM
chosen1's Avatar
Car: 86 Z-28
Engine: 305TPI
Re: fuel pump relay
i have power at the fuel pump harness,but when i turn on the key the test light only stays on for two seconds.is this normal or did i accidently check the wrong wire in the dark?
Old Jan 13, 2009 | 02:50 PM
BigBadLou's Avatar
Engine: TPI
Re: fuel pump relay
That's correct, the ECM only energizes the fuel pump for 2 seconds to prime the fuel system when the ignition is turned on. Then once you crank the engine over, it runs the fuel pump again when it detects pulses from the distributor.
Lou
Old Jan 13, 2009 | 05:29 PM
chosen1's Avatar
Car: 86 Z-28
Engine: 305TPI
Re: fuel pump relay
so if i don't get fuel,is it now time to drop the tank again?i hate doing that job in my driveway...
Old Jan 13, 2009 | 08:07 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: fuel pump relay
Make sure you're getting power to the tank connector first. Dropping the tank is a pain with the car on a hoist. The pass through for it is in the center of the car, just above the drive shaft tunnel, behind the rear seat back.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
